Silverlight 5 Aggiornamenti
Aggiornamento del plug-in utilizzato dalle principali reti radiotelevisive per la diffusione streaming
Silverlight 5 Build 5.1.30214.0 Released March 11, 2014
Release Enhancements
All updates to Silverlight include functional, performance, reliability and security improvements and are backward compatible with web applications built using previous versions of Silverlight.
· Fixes security issue
· Enables reporting of unavailable features in the sandboxed Safari 7 on Mac OS X.
Silverlight 5 (5.1.30317.0)
Risolve un problema nella versione di Microsoft Silverlight 5 per Macintosh (MS14-014) dall'11 marzo 2014.
Include tutte le correzioni di protezione in MS14-014 e sostituisce MS14-014 in Macintosh OS X
langsam fahren
Silverlight 5 (5.1.30514.0)
Fixes issue where a Silverlight application that uses tab-switched controls exhibits a memory leak when you switch between tabs or pages in the application
langsam fahren
